Got the roof rack done so I can carry some gear up on top... Other than that, I recently installed OME springs w/ longer rear 4runner shocks, new stereo w/ amp&sub, calmini belly plates, fire extinguisher, new windshield & rubber, CB & antenna, and herculined the interior... I think she's about ready.
Hi guys,I've been digging through the archive threads on the Fall Classic to see what kind of build it takes to complete the trails you guys are going to be on. I really haven't come up with anything definiative. How "built" does your rig have to be to either go on the Classic or tehe Moab safari?I doubt that I will be able to make this years fall classic, as it's just too late for me to get my act togeather. But I have for the most part finished my '11 GV with the things I plan to do to it. Are big tires and a lift enough for a modern Suzuki to keep up with you guys on the trails you will travel on? As I have only had this little truck for a few months, and I will need to keep this truck running adn in good shape for the next 7 years of ownership, I would prefer to keep body damage to a minimum.Thanks guys,Rob
Quote from: darnold87 on September 30, 2011, 10:50:18 AMGot the roof rack done so I can carry some gear up on top... Other than that, I recently installed OME springs w/ longer rear 4runner shocks, new stereo w/ amp&sub, calmini belly plates, fire extinguisher, new windshield & rubber, CB & antenna, and herculined the interior... I think she's about ready. How do the OME springs ride???
Quote from: crewcabrob on October 03, 2011, 06:06:39 AMHi guys,I've been digging through the archive threads on the Fall Classic to see what kind of build it takes to complete the trails you guys are going to be on. I really haven't come up with anything definiative. How "built" does your rig have to be to either go on the Classic or tehe Moab safari?I doubt that I will be able to make this years fall classic, as it's just too late for me to get my act togeather. But I have for the most part finished my '11 GV with the things I plan to do to it. Are big tires and a lift enough for a modern Suzuki to keep up with you guys on the trails you will travel on? As I have only had this little truck for a few months, and I will need to keep this truck running adn in good shape for the next 7 years of ownership, I would prefer to keep body damage to a minimum.Thanks guys,RobYou would be fine in your rig as it sits, so no needing to get your 'act together' Last year I did the Classic in a bone stock 2000 4 door Tracker with highway radials. The only 'damage' was scratches from trail brush that buffed out with no problem. I did need to push it harder to do some of the sand stuff, but once I got use to running sand on smaller tires, it was fine.Zig Zig
Are most of teh participants for this even local, or are there people that have to drive quite a distance to participate? Rob
