I see that you are sceptical of what I am claiming......no offense, buy the way. I do have to correct you on the lift comment though. I have stated in my recent posts, that it has no lift (suspension, or body) in the rear, and has ONLY a 1-1/2" (suspension) lift in the front. I do have some build pics, on Micro S/D cards, and will post some on here shortly. Since this car has a full frame, I basically used my plasma cutter, and cut absolutely everything that was in the way, front and rear, including removing the upper metal directly above the front wheels, all the way up to the fenders. I moved anything that was in the way (up front) inward, like the battery, radiator overflow, etc. I also had to move the inner wheel wells (that your feet rest on, inside the car), back about 3.5" or so. The pedals clear, as it has no clutch pedal (auto trans), and I did not have to go too far inward. In the rear, I moved the fuel filler neck into the trunk, and so on. I then welded in, and fiberglassed over anything that I felt was neeeded. I will gladly provide you with any specific details, if you want them.
