My current Winch Mount..
The Problem..
It significantly decreases my approach angle.
The plan is to modify the current mounting system by cutting off the lower section (at the red lines in below pic) where it bolts to the lower frame and completely anchoring the top section to my front chassis..
This is how I came up with mounting it..
- 2" x 2" x 0.25" angled steel to weld and bolt to the chassis as shown.
- reason for welding is to increase strength as drilling holes for bolts would be difficult. (radiator etc in the way)
- the 6" wide flat steel will bolt across the angled steel (with 6 bolts as shown) to increase lateral strength.
- my winch mount will now be welded permanently to the 6" wide flat steel. the two horizontal standing bars on the 6" wide steel represent where the current winch mount will rest.
- the factory steel bumper was raised 2" because I added a 2" body lift to the truck. the angled steel will pass just under the steel bumper and through my plastic bumper.
Any recommendations / advice before I proceed would be appreciated.
