Will a Tracker front front diff fit in a Sammy front axle?
  • 22 Replies
  • 3687 Views
« on: February 05, 2012, 06:21:27 AM »
I know the hot set up for going SAS in a Trackick is Toy axles, but I'm heavily invested in ARB lockers and don't want to give them up. I'm thinking of doing something like the Calmini axle swap putting a Sammy front axle with coil front suspension in my Tracker to finally once and for all deal with the IFS and get rid of it.
Before I even contemplate going this route I want to know if  my current front diff will fit in a Sammy front axle housing. I want to keep my gearing and ARB. If so I'll build a Sammy axle with all the good stuff, Cromo axles and such, transfer my 4 door discs and brakes to it too. But that's ONLY if the front chunks are interchangeable.
I'm also not buying a kit, going to fab everything myself. I have access to a Plasma cutting table with CAD so won't have to be cutting brackets and tabs by hand anymore. There is also lots available off the shelf too.
Re: Will a Tracker front front diff fit in a Sammy front axle?
« Reply #1 on: February 05, 2012, 06:54:14 AM »
Yes.  Actually, trackick front diffs fit both front and rear samurai axle housings.
« Reply #2 on: February 05, 2012, 08:18:12 AM »
Thanks Sky, that is going to make this decision a whole lot easier.  8) Now to find a complete sammy front axle.
« Reply #3 on: February 05, 2012, 01:21:35 PM »
If you are running 5.13 gears there may be a clearance problem.  When I built my steel front diff housing out of a Sammy rear housing I had to massage the back side of the housing to allow the gears to turn freely.  I figured that the housing had some rock rash, but my nephew said he had same problem when putting 5.13's in his Sammy, so I think the 5.13's are just that much larger and you can get rubbing.  You can clearly see the depression that I am referring to, and it does straighten out with some large hammer massage from the inside.  So with it dangling down under your rig, I would recommend a diff protector.
« Reply #4 on: February 05, 2012, 02:56:33 PM »
I have heard of a few people having that problem with 5.12s.  Although, far more people don't have the rubbing issue.  I had no issue when I put 5.12s in my samurai axles.
But like you say, a few taps of a hammer, and all is well.
« Reply #5 on: February 05, 2012, 08:11:58 PM »
ya i had to hammer out a little to get my 5.12 in. but all good now! ya hoooo
88 Sammy coils front,rear. 8:1 tcase,5:12,and 37-12.5-16.5 on double beadlocks. arb front spooled back.
96 X90
00 Vitara
« Reply #6 on: February 06, 2012, 02:56:11 PM »
Thanks BRD HNTR and moonzuk, yes  I am running 5.125's, but doing a bit of hammer work is right up my alley. Diff protection a must. I actually think I'll probably have less front end clearance with a sammy axle in front considering how far up the IFS diff sits, but it'll make everything else so much simpler.   Gonna start looking for a Sammy front axle locally or near locally anyway. It's a long term project so I can start gathering stuff I'll need and just keep running the IFS until I have everything.
« Reply #7 on: February 06, 2012, 06:02:11 PM »
Your rig seems perform very good now.  The SAS seems to be easier than trying to keep the IFS as a meat eater.  I am still trying to stay IFS, and would like to see your ride in action.
« Reply #8 on: February 07, 2012, 03:58:42 AM »
Actually BRD HNTR it does perform pretty darn good, has great clearance and rides nice too. The only reason I get frustrated with it is when I have to do some front end maintenance, like I did last weekend, and then have to re align everything. I had a coil that didn't seat correctly on the drivers side, had to drop everything to re seat it, then spent several hours getting the alignment straight again. ( I'm kinda picky about that. ) I used to take it to an alignment shop, but it's 30 miles away, have to make an appointment, blah blah blah. So after watching them do it a few times I made up some tools for measuring camber and toe and do it myself now. Once I get it straight it's fine, but still, SAS seems a lot easier.  I'm just weighing the possibilities really. Now that it's straight and steering right I'll probably get lazy and just enjoy it again!  :laugh: Nice to know I can go the SAS route and keep all my hardware ( ARB, brakes and diffs) though.
« Reply #9 on: February 07, 2012, 07:27:13 AM »
And you can get cromoly axles.
« Reply #10 on: February 07, 2012, 09:46:31 AM »
Yeah, that too.  ;D  Thing is, I get so much enjoyment going over and through obsticles with the IFS that all the big Jeeps and other " serious " off roaders do, it would be a shame to give up the satisfaction of showing them up! :laugh:
« Reply #11 on: February 07, 2012, 06:59:46 PM »
I know the feeling. I have put in a lot of work to keep the IFS, and may have to lower diff again for clearance with the oil pan.  Every modification leads to two more.
« Reply #12 on: February 08, 2012, 05:07:49 AM »
I've already got my front diff sitting so low it just barely clears the front skid plate, maybe 1/4" clearance. If I try and drop it any lower I'll have to lower the skid plate and cross member too. Yeah, one thing sure does lead to another. I think I'm about at the limit as far as lift goes in the front. The Tracker is already top heavy, any more lift and it'll fall over  :laugh:
« Reply #13 on: February 08, 2012, 08:07:24 AM »
Just like I said, "Every modification leads to two more".  When I drop the diff mounts I will have to modify the skid pan too.  Just a couple more mods.
Offline heiney.5
  • 175
  • 9
« Reply #14 on: February 08, 2012, 08:35:31 AM »
Say it ain't so bentparts.....Another one going to defer to the SAS side. :(
I never thought about it, but I do imagine keeping an IFS rode worthy after hard wheeling would probably be another task in itself.
When I first threw gears in my sami project I just ran the front aluminum 3rd member from a tracker with 5:12s. I personally didn't have any problems with fitment. And although I have heard the aluminum is prone to break I had no problems with it after wheeling hard on it. I'm sure if it held up before for you it would hold up on a SAS....
The only drawback I see is you will probably exposing it to rocks from below since the 3rd member wont have the crossmember as a shield, like on IFS. So that would be my only concern with aluminum. I eventually did decide to lock the diff and then converted it to the Sami steel 3rd member.
Keep us posted on the build when it happens.
