I recently acquired a 1988 Samurai. It is stock everything (that I know of) with a rebuilt engine (1.3L).
Adding a lift:
I'd like to add a 1.5-3" lift and add some all terrain tires, but I pretty much know nothing when it comes to this stuff. I also heard anything over 2" and you have to adjust the brake lines and drop the pitman arm?? And do you have to replace the springs and shocks as well or is that standard when lifting a vehicle? New shackles? I know that there are options like the SPOA vs suspension lift, but that's about as far as my extensive knowledge goes. I'm looking for a(n) option(s) that will allow me to drive it daily, but won't break the bank.
Engine:
The engine is an original rebuilt 1.3L. The cylinders were apparently bored out to increase HP. The problem is that it still is lacking quite a bit. It does fine on smaller roads but on the freeway I feel like I'm driving a Go cart... an awesome go cart. Is there anything you can do to increase the HP? Is a turbo an option or did I just lose all credibility by asking that question?
Like I said, I am totally new to this and appreciate any suggestions or advice.
THANKS!!!
