If by draw-through you mean the turbo is between the carb and the intake, I don't think it is a very good idea. From what I've read the air/fuel mix going through the turbo will create problems with transfer of the mixture. A draw-through system is best used with a dry plenum aka multi-port fuel injected setup. I'll see if I can find the exact section in a book that I have. Ah, here it is:
"The draw-through system is simpler and, because it is a low-pressure system, no change occurs in air density at the carburetor. Further, no compressor bypass valve is required. That is all that can be said for the draw-through system.
RULE: The draw-through system is prone to icing at temperatures under 50F.
The blow-through system has better throttle response and cold starting, reduced emissions, and permits use of an intercooler.
Weighing the merits, there is virtually no reason to build a draw-through system unless one lives in a year-round hot climate and never intends to produce serious power." Bell, Corky (1997). "Maximum Boost: Designing, Testing and Installing Turbocharger Systems". pp. 102. Bentley Publishers
Well, I guess that about says it. I hope this comes across just as useful information. I know here on the forums it is hard to get a tone of voice and feel where the person is coming from. I'm just trying to give you some helpful info. Good luck either way. I'd love to see pics of whatever setup you decide. With all that said, I did have a friend who ran 13 psi on a home build draw-through system on his carb'd Mazda truck for a short while - until the engine exploded.
