I'm assuming this must be a matter of National Security...
It is!
Just heading out the door for the race and needed to print out some documentation...
Anyway, there are many ways to skin this cat but I use a cable driven sensor that creates a pulsed signal and then use a conditioner to correct it for the ECM. This way one can have the Sidekick/Trcker cable speedo work and the ECM happy at the same time.
from JTR or Jags that Run I use the:
Speed Sensor, # 4PAC-TOY
Four-pulse sine wave for Toyota with
22 mm metric thread and .187 tang drive.
From Dakota Digital I use the:
SGI-5 Universal Signal Interface Unit
ALso, to calibrate the 4 cylinder Tachometer to work with the V6 ECM output I use:
SGI-8 Tachometer Interface Unit
If you decide to go this way, we can discuss wiring if you need to... but for now, I got to go racing..
