Thank you for the info. That is what I was coming up with also. My transmission, however is an automatic overdrive, and until I fix the wiring, it is only a three speed (1:1 final ratio). As far as off roading goes, I just mess around on dirt roads, and such......no steep hills or rock crawling, so I assume I would be okay. As far as street driving, I just drive around town on errands. No trips longer than a maximum of 7-10 miles each way. I pretty much can't use 4 high, or 2 high with the 35's on it now. I have driven it around (in 4 low) with the 35's on the side roads, and it does fine, however the RPM's are slightly higher than I like. The 39.5's should bring me back down pretty close to where it needs to be. Do you think there is any harm with running the front hubs unlocked with this set up? I am always in 4wd, and don't need to be powering the front wheels. I enclosed a couple of pictures of it (on the 35's.....they, and the wheels are for sale, by the way).I was just starting to make fender flares for it, and obviously, it is not finished yet. I will post pics of it, as soon as I get the 39.5's, and get them on it.
