5 spd won't shift I to 3 or 4
  • 1 Replies
  • 941 Views
Offline zuki1018
  • 397
« on: December 05, 2016, 05:08:51 PM »
87 Sami 5spd.
All other gears workfine, only 3 and 4 do not. I pulled the shifter and can't manage 3 or 4 even with a screw driver. It's like something is frozen/locked up
Long story short, the rig sat for about a year but never had this trouble previously. Not sure what else to diagnose.
On a second note, what causes the truck to roll forward slightly after letting off clutch while in nuetral? TIA
Re: 5 spd won't shift I to 3 or 4
« Reply #1 on: December 09, 2016, 03:47:26 PM »
When I lost 3rd and 4th in my Tracker the issue was that I lost a bearing in the transmission.  If it sat for a while you could also have a stuck shift linkage.  In either case I would get a rebuild kit for the transmission and tear it apart.
