Toyota axles or D44 axles from a 78 wagoneer?
ARMRASTLER
7
September 22, 2011, 02:46:55 PM »
I have a chance to get either stock yota axles for 250.00 or Dana 44 from 1978 wagoneer axles with correct drop front /rear. Not sure which way to go? Both are gonna be stronger than stock Sammy axles but not sure which is stronger between the two upgrades? Any suggestions
87 Sammie 1.3 myside 40mm CV carb,4.56 gears,locked rear,4:1 transfer case,yj swap with missing link,sittin on 31/12.50/15 swampers
ARMRASTLER
7
Re: Toyota axles or D44 axles from a 78 wagoneer?
September 22, 2011, 08:29:53 PM »
Really... No replies??
wildgoody
8134
67
September 22, 2011, 09:22:27 PM »
I say go Yota, it's sort of in the family, so to speak, they Aisin (sp)
make Suzuki Axles also, as well as the transmissions, they are a
division of Toyota
bentparts
4536
60
I'd rather be Blown AND Injected.
Reply #3 on:
September 24, 2011, 07:28:35 AM »
I don't know , Just saw an add in a 4x4 mag about a company that is making BOLT ON portal boxes for D44's that give you 4 inches of lift right there! Now that sounds very interesting.
KJMac
280
3
Reply #4 on:
September 27, 2011, 09:53:03 AM »
The Toyota will save quite a bit of weight! 250 for the yota's is cheap, I would go that route!
Where are you buying them? Around here in the Salem Or are the front is 250-350.
1994 Kick, 16v,header.2.5" exhaust,ported MAF,home made mufflers, K&N filter,5" lift with jeep LJ front springs on the rear and Ford ranger springs on front with 2 3/4 spacers,OME struts with 3" strut spacers,31/10.5 Hankook Dynapro MT on 15x7 black D's.
