No, the tooth shape is different from each other, one is rounded
and the other is square, but if you could find a belt that would
work you have it solved.
There was a post covering this same problem you have, I think he
did some custom thing with the pulley on a lathe, you might want
to see if you can have the same thing done to solve your problem
