ok, this is PROBABLY a crazy idea, and most likely a lot of work, but can you retrofit HID headlights onto a Samurai?
I've had them on several motorcycles i've owned, and just LOVE the increase in my line of sight down the road. it literall jumps from like a football field to roughly half a mile down the road that I can see in pitch black.
is it possible to retrofit those same HID lights to the sammi? assuming I can figure out some way to either install projector headlights, or a headlight bucket that will accept the HID bulb, and put the right reflectors in, personally I see no reason I couldnt do it.
Yes I plan to put an upgraded alternator in, and beef up some electrical stuff, even though HID lights use 50% less power. its just a good idea to keep the charging system pumping out a healthy amount of power while its running.
