You will need some parts off the Tracker/kicker 2.0. The Aerio cooling water outlet goes straight out the back of the motor, which would be into your firewall. The Tracker outlet turns 90 degrees to make it parallel to the firewall.
For the install into Trouble Race Car (a Tracker) we had to get a Tracker 2.0 oil pan, and you need the pickup tube also. You may be able to get by with the Aerio oil pan, especially if you have any lift. I used exhaust pipe to route the cooling return from the back of the motor through the firewall, up to the front of the motor, and across to inlet on radiator.
The Aerio is more than 3 times the HP of a stock Sami, and w/o stronger running gear or a very light foot, I would plan on breaking equipment.
If you get the Aerio from an automatic tranny, the ECU will be throwing error codes for lack of communication with the transmission computer.
