snorkel, header, and 2 1/2 exhaust
  • 19 Replies
  • 4305 Views
Re: snorkel, header, and 2 1/2 exhaust
« Reply #15 on: September 03, 2010, 12:18:14 PM »
2" all the way. ;)
« Reply #16 on: September 03, 2010, 12:37:08 PM »
I would recommend replacing the straight pipe muffler with a turbo muffler at the very least.  A lot of public lands require some sort of spark arrester to avoid setting everything on fire, wthout a cat your muffler is the only thing in the way.
« Reply #17 on: September 05, 2010, 04:55:47 AM »
Yeah, that too!
Offline KJMac
  • 280
« Reply #18 on: September 19, 2010, 12:46:27 PM »
The reason I mentioned the header is the primary tubes seem really big for the size of engine.
I'm a chevy guy and  i had a 327 in my chevelle with 1 3/4" primary pipes and the motor lost a lot of torque
over the 1 5/8". it wasn't anything a 4000 converter couldn't fix! ; )
thanks for the help!!
1994 Kick, 16v,header.2.5" exhaust,ported MAF,home made mufflers, K&N filter,5" lift with jeep LJ front springs on the rear and Ford ranger springs on front with 2 3/4 spacers,OME struts with 3" strut spacers,31/10.5 Hankook Dynapro MT on 15x7 black D's.
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #19 on: September 19, 2010, 03:07:32 PM »
Don't forget about the snorkle, your eng. has to be able to breath. You might be loosing power cause the eng. has to pull harder to get a fresh "breath" Try putting a garden hose in your mouth and run around the block!  ;) I would pull the air intake off and drive it, bet your power comes back. Or try and fab a scoop to help compress the air charge. I've never seen a drag car with a snorkle ???
        Kevin
