sidekick transfercase rotate.
  • 1 Replies
  • 1085 Views
« on: September 10, 2011, 01:38:17 PM »
I have toyotas 3 linked under my kick and my pinion angles are still to much. im looking for the easiset solution to fix this now and i was wondering if anyone had rotated there t-case with a adapter plate to drop the slip yokes down.
Re: sidekick transfercase rotate.
« Reply #1 on: September 10, 2011, 06:53:14 PM »
Are you using a Toyota CV style drive shaft?  If so you can re-do your rear axle to have the pinion point directly at the t-case.  You only need to have the two level if your using U-Joints.
