alright, truck is a daily driver that does WAY to hard of trails. (rockers are shot) the stock exhaust has been bashed off a couple times. work at a muffler shop so bent up a nicer 2" system for it from front pipe back with a nice little baffle bottle. fully welded front to back works nice in the bush, i can scrap it everywhere and i havent broken it yet.
only thing is the joint behind the cat has been removed, smashed it to bits a long time before i did the exhaust and it was welded solid. new exhaust has been done the same.
i dont know if its just my engine mounts are getting bad and the engine is shifting to much on shut down (truck shakes a bit on shut down) or without that joint its just enough to tweak the exhaust, but at the over axle pipe i am getting some cracks forming from the exhaust twisting.
i want to redo the joint on the exhaust but i dont want it in the stock location. would it work enough if i moved it farther up the exhaust into the front pipe? need to rebuild a front pipe cause its on its way out and cat was removed when the exhaust was redone. so the space is there to move it.
