You are going to end up taking the dash all apart to install the
evaporator and running the lines, as well as you need the brackets
and pump, the crank pulley and install the condenser and fan in
front of the radiator, are you sure you don't just want to find one
with a/c already installed? sure you can do it, but what a PITA it
is going to be, I'm not sure I would want to tackle that, and I did
the first 8V turbo setup that I know of
