I suspect your definition of a welded front diff is not the same as his - he has a second gen, so the front diff contains a pneumatic freewheel clutch, which can be problematic, and some folks weld it engaged and then fit freewheeling front hubs - the end result is a front axle assembly that is equivalent to the ones you have.
