Tracker PS on 1.6/8v SJ 33"
  • 880 Views
Offline mbruce
  • 139
« on: May 29, 2011, 08:03:46 PM »
Just wondering if the PS on a tracker will hold up to turning 33" tires? I read the washer trick that can increase pressure...
It would be super easy and convenient if it worked since I can just bolt it on and turn away!
What size pitarm is needed for a SPOA?
Anyone have any rubbing issues with running 33" tires on a SPOA ?
Thanks!
Ignorant questions lead to a wealth of knowledge
Re: Tracker PS on 1.6/8v SJ 33"
« Reply #1 on: May 30, 2011, 05:06:22 PM »
The power steering unit will hold up to 33" tires, but you will want to put a power steering cooler on it.
Offline mbruce
  • 139
« Reply #2 on: May 30, 2011, 06:37:40 PM »
Cool - thanks!
And I read about the simple washer trick that adds more PSI...and then the 1/64th drill-bit hole to some part that allows more fluid thru?  but that may shorten the life of the pump....
I'll find a cooler.
