weber to stock air cleaner
  • 1117 Views
Offline jessekvfd
  • 11
« on: March 22, 2012, 07:31:37 PM »
  Hello,
  In hooking a weber to the stock air filter do I need the stud and wing nut that would have been on the stock carb? The po put the weber on but lacking funds cut up a square Tupperware container to hook it all together. I need to order the clamps for the air intake tube and adapter and need to know if I need the stud and wing nut. Thank you.
Offline rascott
  • 669
  • 15
Re: weber to stock air cleaner
« Reply #1 on: March 22, 2012, 08:49:10 PM »
weber(redline) has adapters to use the stock air cleaner. my sidekick air cleaner is different than a samurai, but the stock carb is similar. i use an appropriate length 6mm bolt to fasten the air cleaner to the adapter.
Offline jessekvfd
  • 11
« Reply #2 on: March 22, 2012, 09:10:14 PM »
Thanks for the answer. I was wondering if a bolt would work.
