Samurai front axle 26 spline conversion
CCOR
ZUKIWORLD Online!
December 28, 2015, 07:10:24 AM »
I've got a 1988 Samurai at the shop with 22 spline axles in front. Is there a make model, year that was equipped with 26 spline axle shafts that I can get shafts from instead of buying aftermarket chromoly axles?
Thanks,
Bobby
sspence81
6
ZUKIWORLD Online!
Re: Samurai front axle 26 spline conversion
January 02, 2016, 12:51:26 PM »
My 88 1/2 has 26 spline front axles. I know because I just took my differentials to get new ring and pinion installed and I checked to see if the front and back were the same.
Ruby
26
I love YaBB 1G - SP1!
January 02, 2016, 06:34:21 PM »
All samurai stock fronts are 22 spline
nprecon
2318
52
ONWARD... through the fog!
Reply #3 on:
January 05, 2016, 02:03:46 PM »
The Sammy with the 26 spline front axles probably has aftermarket axles in it and the side gears were swapped out with side gears from a Sidekick or Tracker to run the newer aftermarket (chromo?) axles.
'02 Chezuki Tracker with a 2 Liter and 5spd. It works for me!!!
Skyhiranger
3734
122
I don't buy, what I can build
Reply #4 on:
January 07, 2016, 05:40:20 AM »
All US samurais had 22 spline front axles, from the factory.
Usually people find 26 spline rear sidegears and swap in the front (or swap the whole third from a rear of a samurai into the front), in order to run the aftermarket 26 spline front axles.
