putting tracker power steering in a samurai
  • 9 Replies
  • 4449 Views
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
« on: February 04, 2011, 05:46:42 PM »
I have a 16v in my sami  I know a have to drill the frame and sleeve it to mount the box what is the eazyest way to hook up the shaft between the colum and box I have both shafts sami and tracker I font want to buy anything if I don't need to
« Last Edit: February 04, 2011, 05:48:31 PM by fordguy79 »
Re: putting tracker power steering in a samurai
« Reply #1 on: February 04, 2011, 05:57:23 PM »
Use the box end of the tracker shaft and the steering column side of the samurai shaft.  Cut both of them shorter, collapse the samurai shaft and weld them together.
Here is what my "bastard shaft" looked like, after I cut them down and welded them together.
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
« Reply #2 on: February 05, 2011, 04:52:51 PM »
got the box mounted now the pump hits the box steering shaft has no room if i cant figure this out tonight i will sell the whole setup    It's a  94 tracker box and pump
« Reply #3 on: February 05, 2011, 05:01:52 PM »
You can't use the stock placement of the PS pump.  It has to be moved higher, in order to clear the box.  Hopefully you are not running an AC compressor, because I don't know how you mount the pump to clear the box, with AC.
Offline yzf438
  • 94
« Reply #4 on: February 05, 2011, 05:03:50 PM »
I had to fab my own mounting bracket for the pump to get it higher. too cheap to pay for kits that someone else built I guess.. pretty easy little job
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
« Reply #5 on: February 05, 2011, 05:05:42 PM »
no ac  any pic's?
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
« Reply #6 on: February 06, 2011, 08:39:44 PM »
DONE
Offline tuxblacray
  • 20
    • Tuxblacray Photos
« Reply #7 on: February 09, 2011, 04:39:22 PM »
So where are your pics? Maybe even a little quick write up? I'm bett'n there will be some other dude (like maybe me) who would love to see what you did for a future reference!
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
« Reply #8 on: February 13, 2011, 11:13:56 PM »
here are some pic from the install sorry o didnt take pic well i was doing it i forgot
http://www.facebook.com/album.php?aid=3793&id=1812492167&l=38331b9a0a
you can see the plate i made up to mount the pump and the holes i drilled and sleeved on the frame it was easy i just should of asked more questions before i started would of made it faster to do
« Last Edit: February 13, 2011, 11:17:56 PM by fordguy79 »
Offline tuxblacray
  • 20
    • Tuxblacray Photos
« Reply #9 on: February 14, 2011, 03:56:13 PM »
ThxzJon! I got the general idea based on your pics.... Incidently don't worry... I have shot some of the worlds worst pics! I just make sure I take a ton of em and I alwaays get at least a few good ones!  :laugh:
