Every once in a while take a peak under that header wrap, that stuff likes to hold moisture. Even if you get it good and hot it can sometimes stay damp. Past experience with the Harley crowd, working on bikes that had header wrap showed some nasty corrosion under some wraps. It just may be the type they used, but I'd check it anyway. That's a nice header and wouldn't wanna see it get ugly. I was going to wrap my turbo manifold to keep the heat in but I've found the heat retention qualities of stainless are so good it's not an issue or even recommended.
For your exhaust, I like aluminized mild steel exhaust tubing, it really is corrosion resistant and cleaned thouroghly and painted with a good header paint ( I used a ceramic based spray) it really does not rust or corrode either.
