Do a cam, I have an 8V and a custom grind Engle Cam, but I
recall the cam really helped the engine come alive, you could
do some port cleanup get rid of the casting imperfections, and
some of the under valve seat issues, there was a significant lip
on the head I have that I thought would really mess with the
performance, so I worked on that, as well as I smoothed out
the chambers to reduce hot spots, I was working this head for
turbo use, you may not want to work the chambers that much
as it will reduce the compression ratio slightly, tho not enough
to really cause any power losses.
Happy Porting
