As mentioned, 96s and up have 26 spline front axleshafts. So if you happen to get a pre 96, just grab the passengers side CV axleshaft too.....that way you can just swap your passengers side CV shaft out for the "new one and if you get the complete front housing (axle housing, third, drivers side axleshaft that is inside the housing) your drivers side CV axleshaft will bolt right up to the drivers side axleshaft that is in the "new" housing. Or you can just swap sidegears too....but that requires you to pull the ring gear off the carrier, take the carrier apart, swap sidegears, and put it back together exactly to the same specs as it was before you took it apart (not hard to do, if you take your time and precisely mark everything before disassembly, just takes longer than swapping out a passengers side CV shaft).
Your trackick should have 4.30s in it now.
That list that you got from kickfix is accurate (99% of it is info that I posted on various forums).
