engine swap
engine swap
dirtyboy
10
engine swap
May 14, 2011, 03:06:00 PM »
Can I swap my 97 engine with a 92 engine out of a tracker I know I have to change distributors What else.
wildgoody
8134
67
Re: engine swap
May 14, 2011, 03:10:09 PM »
Yes, so long as the engines are the same valve count, 8V for 8V and 16V for 16V
unless you plan on swapping over the cylinder head
dirtyboy
10
Re: engine swap
May 14, 2011, 03:15:27 PM »
16v and what about the crank sensor.
wildgoody
8134
67
Re: engine swap
Reply #3 on:
May 14, 2011, 03:19:08 PM »
Ya, I figured if you knew about the distributor, you know about the CPS.
You have to match the electrics to work with your body application, you
would need to swap the oil pump and pan if you need a CPS on a 92 engine
dirtyboy
10
Re: engine swap
Reply #4 on:
May 15, 2011, 10:32:26 AM »
oil pump and pan, or just oil pan? thanks
wildgoody
8134
67
Re: engine swap
Reply #5 on:
May 15, 2011, 11:14:16 AM »
The pump housing holds the CPS, so you need to swap the whole part.
Might be a good time to install a new pump too, as long as it's getting swapped
dirtyboy
10
Re: engine swap
Reply #6 on:
May 15, 2011, 12:15:06 PM »
new pump was installed when rebuild, so I need to change pans and hook up sensor.
SIDEKICK65
176
Re: engine swap
Reply #7 on:
May 15, 2011, 03:33:24 PM »
are you putting a 16 valve head on a 8 valve motor?
dirtyboy
10
Re: engine swap
Reply #8 on:
May 15, 2011, 07:49:32 PM »
No 16v from 92 rebuilt, in 97 body.
