yj springs question
yj springs question
yzf438
94
yj springs question
May 07, 2011, 09:08:59 AM »
88 samurai.
so am doing the yj springs kit. I ended up with front and rear springs off a friends yj after he did the lift on it.
how do I tell which ones are the fronts and backs? I asked him and he said not a clue.
thinking the set with more packs goes in the front for the engine weight?
is this correct?
thanks
my996duc1
222
7
Re: yj springs question
May 08, 2011, 03:06:31 AM »
you can run whichever ones you want on the front or back of the Sami.
I am running two sets of rear with yet another main leaf added to each pack on mine.
On the Jeep, the 4 pack was front and the 5 pack is rear.
1987 Tintop / 1.6 16V ps & ac / 6.4 t-case Twisted TT / 4.30 R&P Hybrid rear / Double Tough axles / Shrockworks all around / ARB f&r / Mighty Kong & TT full skid / DS disconnect / CV shafts f & r / YJ missing links f & r / Petroworks tintop cage / 15 gal Tank / 31" x 12.50 Pro Comps
LostZuk
16
May 29, 2011, 04:56:35 PM »
I run them 4 front 5 rear on mine and I go through several a year but I tend to work them hard. I am thinking about linking the rear as they seem to go more often.
I'll wheel with anyone, even Jeeps as longs as they can keep up
