Torque on Rear Pinion nut?
Momo
12
February 16, 2012, 05:10:05 PM »
I just finished rebuilding my rear diff in my 88 Sammi and am trying to find out what the torque spec is for the pinion nut. I know it has to crush the crush sleeve but I don't want to over tighten it. All the bearings are new and so is the crush sleeve ect.. Any help would be appreciated.
88 Sammi, 1.3L with CV Harley carb and Thorley header, 6" SPOA, Trail Tough 2" springs, 4.62 gears with Lockrite Lockers, 4.16:1 TC, Customs bumpers. 33" Pitbull Rockers, And lot's of other little mods!
Time to get DIRTY!
my88samurai
43
Re: Torque on Rear Pinion nut?
February 17, 2012, 05:46:40 AM »
Tighten it until it has zero endplay. Just did mine a few weeks ago. I had to use a 3/4 impact gun. The crush sleeve is hard to get to start colapsing but once it starts it's not that bad. Keep tighting a little then feeling the play and keep doing it untill all tha play is gone.
BRD HNTR
2300
56
February 17, 2012, 07:10:06 AM »
I believe the FSM says tighten it until it takes 11 inch pounds to rotate the pinion shaft. It does take lots of torque (probably more than 150 ft/lbs) just to get crush sleeve to start crushing. The pinion nut is not set by direct torque. Go to the FSM or
ACKS has a file on rebuilding the differential.
http://www.acksfaq.com/samuraiDifrebuildFSM.htm
93 Tracker,XL7 springs & 1" raised spring pads in front with YJ springs in back, home built bumpers rear & front (w/winch), 2" x 4" rock tubes, ARB front & rear, converted Sami rear to IFS, 33x12.5x15 aluminum rims, roll cage, 2.7L w/5 speed auto.
Drone637
8121
116
Evil Cow
Reply #3 on:
February 20, 2012, 01:22:29 PM »
We just did a diff this weekend, took a lot of force. So I looked it up in the FSM, it lists 250-400lbs force may be required to crush the sleeve. Fun times!
