Pics of Zaggys Engine
  • 73 Replies
  • 25281 Views
Offline zaggy
  • 1134
Re: Pics of Zaggys Engine
« Reply #60 on: September 26, 2005, 10:49:49 AM »
Hey Rhinoman
You wanted pics.....here's one from just before the first flight, more once I recharge the camera so I can download.
Zag
Offline zaggy
  • 1134
« Reply #61 on: January 09, 2007, 08:00:25 AM »
Just an update for those interested...
This project has worked out pretty well, flight testing is complete and the engine has about 120hrs flight and ground test time on it now.
- Climb 800 fpm
-Cruise 120mph
-Top 130mph
Engine runs well but due to our cold weather (-20 to -30C) I've had a lot of cold start problems.
Solution....starting building a custom multi port fuel injection system.
Engine currently puts out 110-115hp |removethispart|@ 6000rpm based on thrust and performance of aircraft.
With the multi point injection I hope to maintain the performance and beat the cold start
Zag
« Reply #62 on: January 09, 2007, 05:45:03 PM »
 ;) Zaggy, You are amazing! That is one hellofa project. KUDOS!
Offline zaggy
  • 1134
« Reply #63 on: January 10, 2007, 07:39:55 PM »
Thanks Bentparts
Next project coming up aircraft wise is a 1.3/8valve should be about 80-85 hp and is destined for another homebuilt.
Currently have several 1.0's flying
1.3/8 valve out there somewhere on an airboat
1.6/8valve on this aircraft
1.6/8valve in my current sideKick that will become test project this spring
1.6/16 valve to be swapped for a 2.0/16valve if I ever get back to working on it (wifes Kick)
It's fun to play
Zaggy
« Reply #64 on: January 10, 2007, 07:46:28 PM »
Zag,
God to hear it's holding up for you good. Good to see you back again  ;) Have a great week and keep us updated.
« Reply #65 on: January 11, 2007, 05:01:49 AM »
Hey Rhinoman
Zag
Hey, Zaggy is that camera still on charge??
Offline zaggy
  • 1134
« Reply #66 on: January 11, 2007, 10:02:17 AM »
Boy am I loosing it...
Soon as I get near my home computer I will post some pics Rhinoman
Zaggy
PSYKOCHI
« Reply #67 on: January 15, 2007, 05:59:41 PM »
 ;D  Zaggy, excellent job on your plane....could you give me some advice on my drag racing 1.6L Geo Tracker......I am needing some additional HP.  Look below for my video site.  17.5 sec. |removethispart|@ 73mph.
« Last Edit: January 15, 2007, 06:02:34 PM by PSYKOCHI »
Offline zaggy
  • 1134
« Reply #68 on: January 17, 2007, 05:51:35 PM »
Hi Psykochi
Be glad to help...I used to drag race myself, last car was a 240Z (love teasing V-8's), over 100mph in the 1/4 on reg fuel no blowers or electronics.
Whole car was built for less than a strong V-8.
Can I get some basic info
-weight
-gear ratio
-tire size
-engine internals including cam (if not stock)
-current bolt on goodies (type of intake/exhaust, any EFI mods, stock ignition or modified?)
-listening to the video I assume it's a 5 speed
Zag
Offline zaggy
  • 1134
« Reply #69 on: January 26, 2007, 12:46:45 PM »
Here the pics I promised Rhinoman
Zag
Offline zaggy
  • 1134
« Reply #70 on: January 26, 2007, 12:48:43 PM »
nother one
Offline zaggy
  • 1134
« Reply #71 on: January 26, 2007, 12:51:00 PM »
So with a 1600/8valve Sidekick engine does that make it the highest/ fastest tracker?
Zag
« Reply #72 on: January 26, 2007, 01:39:07 PM »
Thats cool, good to see it in the air  ;D
Offline zaggy
  • 1134
Re: Pics of Zaggys Engine and now the airplane
« Reply #73 on: January 26, 2007, 04:46:48 PM »
Meant to add this one earlier
Zag
BTW
max altitude so far in testing 12,000 feet
max speed so far 145mph in a shallow dive
max cruise so far in level flight 120mph
Still some work to do on the airframe
