deep water modifications
  • 17 Replies
  • 4059 Views
Offline greg51
  • FISHING IN THE BIGHORNS
« on: March 20, 2011, 08:00:03 PM »
88 Sami. What are the steps to modify for deep water other then a snorkel?-------------Thanks---- Greg
« Last Edit: March 20, 2011, 08:08:53 PM by greg51 »
  • 4320
  • 167
Re: deep water modifications
« Reply #1 on: March 20, 2011, 09:04:52 PM »
A diesel engine?
There's a video on YouTube showing a guy with a blue diesel engined Samurai driving around a quarry with just the roof & snorkel out of the water - if he had tried it with a gasolene engine it would have died the minute the ignition got wet.
On a more serious note - you do need to keep the electrics dry, and one way to do it is with an electric fan that you can switch off before entering the water - if the fan just dips the blades into the water, they lift the water and throw it all over the engine bay - another reason to stop the fan before entering water is that it can act as a propellor, and when it attempts to pull the vehicle through the water, the blades flex, sometimes far enough that they can cut or damage the radiator core and cause leaks.
Farley quarry 20/5/07 suzuki sj water
Here's that video I mentioned.
« Last Edit: March 21, 2011, 06:29:08 AM by fordem »
« Reply #2 on: March 21, 2011, 04:15:13 AM »
Use Dielectric grease on ALL electrical connections, including spark plug wires. And have a tow strap already connected to your rig  :laugh:
Offline tuxblacray
  • 20
    • Tuxblacray Photos
« Reply #3 on: March 21, 2011, 12:40:49 PM »
Look at and waterproof any place that can be opened. Lengthen all breather tubes above the water line or inclose them. Dielectric grease works great. I also spray all of the plug wires, cap, electric connections with spray silcone sealant. I rubber silcone the distributor cap down. My rear end breather tube runs up into the inside of the body by the gas filler tube and tank vent. My front end tube runs up an through the firewall into the cab. I tape my dipstick down so it can't come loose. Over flow tank breathers are capped shut for that day. air breather is siliconed shut and the intake tube is sealed and draws air in from the under the dash for that day.
« Reply #4 on: March 23, 2011, 06:52:40 PM »
Dang Tux, wouldn't it be easier to just stay out of the deep water  :laugh:
« Reply #5 on: March 25, 2011, 03:51:37 AM »
Really!  :laugh:
Offline tuxblacray
  • 20
    • Tuxblacray Photos
« Reply #6 on: March 27, 2011, 04:02:28 AM »
He asked.....  :o But I will say this.... round here in my neck of the woods this stuff will save yer money pocket. There is alot muddin here. Unfortunitly not everybody drives Sammy's or Kick's... etc. There are some holes out there that look tame but end up being like Farley's Quarry. It's the fault of them durn Ford guys with them big ol 40's that keep gettin stuck where we like to play.....  :laugh:
« Reply #7 on: March 27, 2011, 05:18:29 AM »
Fords!  :P
  • 4320
  • 167
« Reply #8 on: March 27, 2011, 06:37:56 AM »
Did someone call my name?
« Reply #9 on: March 27, 2011, 07:35:39 AM »
 Easy there, Trigger. Some of us have more than just 'zuks in the herd. WE happen to have a few of the afore mentioned trucks, and use them for eveything BUT mall crawling. That is handled by the Cherokee.
Offline tuxblacray
  • 20
    • Tuxblacray Photos
« Reply #10 on: March 27, 2011, 09:59:50 AM »
Just some good fun intended.... I'm a Bow Tie Guy by nature so teasin the Ferd Guys is justa reality. I have owned a ton of 4wd's and I would hafta say my favorite was an 84 F150.
The meat of the message was them big ol trucks can make swimmin fer our lil rigs an instant reality. For a real thrill run down some of the Indiana loggin roads at night. 1st one to make the headlights go under wins the OH CRAP award.......  :laugh:
« Reply #11 on: March 27, 2011, 03:21:38 PM »
Yeah, I know. Just the normal "my brand can..." stuff. Oh, as far as the logging roads up there in Indy, heck, son you ought to try some of the creek crossings down here in Kentuck. 89 Bronco on 38s' and the WHOLE freakin' thing disappeared up to the roofline 'cause some clown on 52s' thought it would be fun to dig in the sand right where everybody goes across. STUPID F'ker. Owes me a full rebuild on the Bronco when I catch him/her/it.
« Reply #12 on: March 27, 2011, 10:28:32 PM »
Dielectric grease is a better option than any other ideas. I have not tried it on my own but I am sure it will work.
« Reply #13 on: March 28, 2011, 08:00:53 AM »
 Nobody has mentioned the rest of the drivetrain really, other than the axle vents, so........   a GOOD quality lithium/marine grease does wonders for the bearings, u-joints, slip joints in the driveshafts, etc, rasing the vents for the tranny/xcase up to at least the firewall, doing something about the "drain tubes" in the headlights, and NOT turning the mothers ON when they are under ( cracked lens, anyone? ) using Di-electric grease to "backfill" the connectors on the wiring for lights, sensors, etc. AND figuring out a way to water proof the ECU.
Offline Jluck
  • 1389
  • 40
« Reply #14 on: March 28, 2011, 08:46:55 AM »
try these enclosed bellow vents for diffs/gear boxes.
http://www.lowrangeoffroad.com/featured-products/do-it-yourself-rubber-differential-breather-bellow.html
and keep in mind if you drop in to some cold water with a vehicle thats up to operating temp your diffsgear boxes,ujoints,etc. can pull in water around seals. so plan on a enormous amount of servicing and fluid flushes.
back in the full-size truck days, we primarily wheeled in deep water/mud and coastal wetlands (earth-muffin greenies piss-off). I would count on fluid flushes and a full tube of grease after every run. (gets damn old and spendy)
the best tube-o-grease I ever found was Lucas "red and tacky"
