Propane Carburetors
  • 0 Replies
  • 1031 Views
Propane Carburetors
« on: May 11, 2011, 04:14:17 AM »
Well, here I am again asking another LPG related question.
I'm looking buy an all-in-one propane/LPG mixer and throttle body to replace this overly complicated setup.
I currently use the standard Aisan carb (i'm an Aussie) with a mixer ring on top as per the picture above, but under the hood is too busy with a mile of vacuum lines and hoses that are un-needed for my purposes... now the car is getting old there's regular vacuum breaches to sort out, be it in the lines or in the gaskets of the carb.
I want to replace my mixer ring and carb, yet keep the stock airbox if possible.  I don't want to have to replace the other 99% of the LPG system by upgrading, but I don't want to go backwards in HP either.  I can sort out an adaptor plate easy enough too.
Any suggestions?  I can't really find that much info on the topic, and i'm always terrible at finding answers online  ???  Seeing there's 100's of propane zooks over there i'll see if you can help me
« Last Edit: May 11, 2011, 05:14:24 AM by che_guitarra »
