alternator upgrade
  • 9 Replies
  • 3254 Views
Offline P Funk
  • 29
alternator upgrade
« on: October 21, 2011, 10:27:37 PM »
I have seen a few different kits online to upgrade to the 100(ish) amp delco 10si/12si alternator.  Is this the best option, or is there a factory suzuki alternator that would be a straight up bolt in?  I want to do some electrical upgrades such as offroad lights and maybe a subwoofer and the stock alternator doesn't seem up to the task.  Any "bright" ideas?
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
Re: alternator upgrade
« Reply #1 on: October 22, 2011, 07:19:52 AM »
I have a winch lights and a sub with a 200w amp my stock samurai alternator was not up to the task under light use of the winch and lights at night  so i upgraded to a ac delco 3342201 can also be found as 7294-3  its a stock alt for a 84' camaro with a 94 amp alt  much better and it cheep alot cheeper than a 100amp was almost $50 cheeper
« Reply #2 on: October 22, 2011, 08:46:02 AM »
Did you have to use aftermarket brakets or was it more or less a bolt in?
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
« Reply #3 on: October 22, 2011, 09:21:13 AM »
after market lower bracket stock upper        http://www.lowrangeoffroad.com/index.php/suzuki/samurai/engine-upgrade/gm-alternator-bracket.html   it was cheaper than replacing a stock alt
« Reply #4 on: October 22, 2011, 08:12:46 PM »
Does the original plug still work?
01 Tracker - OME Springs, 2" MK1 Body Lift, Warn 6K Winch, 18x9 Wheels, Rear Roll Cage and more.  95 Tracker with all Calmini bolt ons.  96 X-90 with mini lift and Super Swampers, this one has A/C and is an auto, nice.
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
« Reply #5 on: October 22, 2011, 08:37:08 PM »
no you will have to cut the plug or splice in  i have seen people use male spade ends pluged in the the stock plug.   My plug had a wire brake off long before i upgraded to the delco
http://www.lowrangeoffroad.com/index.php/catalog/product/gallery/id/157/image/2035/
http://www.lowrangeoffroad.com/index.php/catalog/product/gallery/id/157/image/2034/
 i wired mine like the second link
Offline Momo
  • 12
« Reply #6 on: October 22, 2011, 08:54:53 PM »
I went with the kit from Petroworks and it's awesome. It took minutes to put in and runs everything no problem. I run offroad 100w lights (4), Winch, Stereo, Inverter, 2 flood lights (rear 55w) and never have a problem. They supply the proper plug and bracket. If you don't want to get the alt thru them they will let you know what one to get from your local parts place or even a rebuild one. They're a great company to go through and easy to talk to. Hope this helps
88 Sammi, 1.3L with CV Harley carb and Thorley header, 6" SPOA, Trail Tough 2" springs, 4.62 gears with Lockrite Lockers, 4.16:1 TC, Customs bumpers. 33" Pitbull Rockers, And lot's of other little mods!
Time to get DIRTY!
Offline talonxracer
  • 1284
« Reply #7 on: October 24, 2011, 07:52:34 PM »
The TT bracket works awesome, they include the pigtail and instructions on the correct way to hook it up.
Make sure that you ALSO procure the proper alternator bolt mount sleeve, otherwise the alternator can cock in it's mount after awhile of running.
Offline ranger88den
  • 279
  • 12
« Reply #8 on: October 25, 2011, 11:32:30 AM »
How long ago did you buy yours?  I bought my TT bracket from Low Range Off Road about 2 mos. ago and didn't get a pig tail.  Well made bracket though.
Offline talonxracer
  • 1284
« Reply #9 on: October 25, 2011, 12:09:59 PM »
I got it about 2 months ago as well, I am almost 100% positive the pigtail was included, but I could have been hallucinating as well...LOL...but i dont remember ever having one around the garage or snagging one at the auto parts store either.....a mystery right there.....LOL
