Can't Take The Heat! HELP!
  • 32 Replies
  • 5322 Views
Offline ecoast
  • 509
  • 8
    • East Coast Canvas
Re: Can't Take The Heat! HELP!
« Reply #30 on: May 05, 2011, 04:35:08 AM »
yep, they always are in motion
« Reply #31 on: May 05, 2011, 06:14:43 AM »
I will turn, but it's not locked on to the clutch, if you slow it down
with a gloved hand (assuming it's not engaged) you could hold the
blade still while the engine runs, it's just turning as a product of it's
drive being turned, kind of like those bling bling spinner wheels
« Reply #32 on: May 05, 2011, 04:51:11 PM »
Water would have to be half way up the door before it could be a problem,
and then once the fan clutch is cool, it will not drive the fan so no worries
Half way up the door is pretty common for a NJ forest run, they don't call these the " wetlands " for nothin'  :laugh: I'll still take any opportunity to go around if available though   ;)
I'm really looking forward to going out asap to give it a good, long stressful test, but so far Soooooo good!  Thanks again all for your help, insights and encouragement.
