5:12's Too Low?
  • 1184 Views
Offline one mile
  • 174
5:12's Too Low?
« on: October 12, 2010, 08:28:54 PM »
On a stock Samurai with 30"tall tires steet driven 90% of the time are 5:12's O.K.?
"WORK SMART NOT HARD"
Offline my996duc1
  • 222
Re: 5:12's Too Low?
« Reply #1 on: October 12, 2010, 09:03:00 PM »
it should work but if you can go t-case and ring & pinion gears you will get a better combo.
My '87 had 5.12 gears and stock t-case with 31" tires for awhile.
I was turning 4200rpm at 65mph with a low range crawl ratio of 42:1
This had my speedo off by about 10mph and the odo was off too.
Now I am running 4.30 gears and a 6.4 t-case with 31" tires.
I am turning 4100rpm at 65mph with a low range crawl ratio of 100:1
Speedo / Odo are almost spot on.
Here is a good calculator for figuring speed/rpm/crawl ratio/ ect....
Keep in mind that your tires may not be the size advertised on the sidewall.
http://www.grimmjeeper.com/gears.html
1987 Tintop / 1.6 16V ps & ac / 6.4 t-case Twisted TT / 4.30 R&P Hybrid rear / Double Tough axles / Shrockworks all around / ARB f&r / Mighty Kong & TT full skid / DS disconnect / CV shafts f & r / YJ missing links f & r / Petroworks tintop cage / 15 gal Tank / 31" x 12.50 Pro Comps
Re: 5:12's Too Low?
« Reply #2 on: October 13, 2010, 08:28:09 AM »
That's a great calculator, gives you 2 screens to play with #s and look at results side by side
