Adapter plate for a beginning, is the 1.3 Injected? MPI or TBI?
You might be able to use the old EFI to run the bigger 1.6
engine, you might have to swap injectors or the new MPI manifold
could work with old EFI system.
The problem with your ? is nobody in the USA has easy access to
a Jimny so we really don't know what the details of your engines
are so I'm just speculating here, but if you send some detailed
pictures of both engines we might be able to guess better
