rear axle seals?
  • 10 Replies
  • 2379 Views
Offline zukibalz
  • 16
rear axle seals?
« on: January 08, 2010, 11:21:36 AM »
need to know where i can get axle seals for my 88 samurai. i have a mini spool to put in but not sure what seals are needed to do this. asked napa and advance auto for rear axle seals and they say they cant find them. what to do?
Re: rear axle seals?
« Reply #1 on: January 08, 2010, 06:15:59 PM »
What seal are you talking about??? The 3rd member doesn't have a seal, it's
gray silicone for that, and the axle seals as well as the pinion seal should be
easy to find, if not call Hawks or Petroworks, bet they have them
Offline zukibalz
  • 16
« Reply #2 on: January 08, 2010, 07:00:36 PM »
napa and advance auto have no seals for any part of the rear axle in my area. i dont know why. i have no idea about these samurais i just baught one and am trying to learn the ins and outs of it. fun little woodser though!!!
Offline zukibalz
  • 16
« Reply #3 on: January 08, 2010, 07:10:47 PM »
i found a wheel seal kit and pinion seal kit. is that what i need?
« Reply #4 on: January 09, 2010, 09:34:45 AM »
I think that is what they are called, worst case is get the #s off of the
seals and get them from a seal supply company, that's what I have
done to save big $$ on seals instead of getting them thru the dealers
or the autoparts stores
You could look those #s up online and get them sent to your door
if you wanted
« Reply #5 on: January 09, 2010, 10:29:33 AM »
You shouldn't need anything to drop in a mini-spool as long as you are careful pulling your rear axles out.  If your worried about it you could get a new set of rear wheel bearings along with a rear axle seal, Low Range Off-Road has them available for 45 dollars.  As for the third member, just use some silicone and give it time to setup.
Offline zukibalz
  • 16
« Reply #6 on: January 09, 2010, 12:49:16 PM »
is the front and rear the same when it comes to seals?  ???
« Reply #7 on: January 09, 2010, 10:03:51 PM »
Ya, I think they are
« Reply #8 on: January 10, 2010, 06:51:00 AM »
Which seals specifically?  If you are talking pinion seals, then yes, they are the same.  If you are talking about axle seals, then no, they are nowhere near the same.
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
« Reply #9 on: January 13, 2010, 06:24:42 PM »
710193   timkin seal     they just dont know where to look    i'm a counterman at a small parts house took me 3 minutes like just like the ones i changed  10.93 each         same # for national seal   and parts master   good luck
Offline Jackdar
  • 26
« Reply #10 on: January 15, 2010, 07:17:33 AM »
18962 at NAPA for axle
1994 Geo Tracker 2wd
