New Struts??? Jeffs 2" lift.
  • 1113 Views
Offline ColtonP
  • 147
« on: July 22, 2012, 11:59:08 AM »
I have a 2000 chevy tracker 4door 4x4. 2.0. i just lifted the struts are very tired. I was wondering if there are any part number that will compensate for the 2 inch lift so i don't have to drill and hammer a brand new set of struts. i want to remove the strut and strut spacer and slide in the new struts. THANKS PICS ALWAYS HELP
1987 Suzuki samurai BONE STOCK
(SOLD)1990 Samurai 1.6 8v swap, Arb front air locker, spool rear, RRO coil suspension, Chromoly front axles, 33x13.5-15 Swampers, ARB Bumpers, Slider, fender flares, 6.5:1 transfer case, True beadlocks, 1.5" wheel spacers,Roll cage. All in all a lil over 10k in parts uuuggghhhh!!!!!(SOLD)
(SOLD) 2000 Chevy tracker, 4 door, 4x4, auto trans, 2 inch lift,265/70r16 (SOLD)
(TOTALED)1995 tracker lsi, tintop, 3speed auto trans, 2 inch lift, 2 1/2 inch exhaust, 30x 9.5 bfg a/ts, custom front bumper.(TOTALED)
Re: New Struts??? Jeffs 2" lift.
« Reply #1 on: July 23, 2012, 04:42:17 AM »
You could try and find out if OME makes a strut for that year. They're about 1.5" longer , have more travel and work great. If you don't want to " drill or slot " you'll probably need some camber bolts to correct your alignment as well.
« Last Edit: July 23, 2012, 04:44:47 AM by bentparts »
Offline nprecon
  • 2318
  • 52
  • ONWARD... through the fog!
« Reply #2 on: July 24, 2012, 08:43:06 PM »
I have a 2002 Tracker, ordered a complete OME suspension from Brent  at Trail Tough, installed the components, and my camber was ALMOST dead on using standard strut bolts.  on both of my 2nd gen trucks the OME springs replaced the 1 1/2" coil spacers and the lift was almost identical.
« Last Edit: July 24, 2012, 08:49:17 PM by nprecon »
