Just instaled jeffs 2" lift have a few questions!!!
  • 1226 Views
Offline ColtonP
  • 147
« on: July 14, 2012, 05:32:17 PM »
I recently bought and installed jeffs 2 inch lift. My rides specs are(2000 chevy tracker,4door, jeffs 2" lift, 2.0 4 cylinder, 4x4,265/70/r16 on dick cepek rims (yes they rub), stock everything else.)
  My questions are as follows.
1. Do i need my sway bar??? After the install i could not get it to reconnect so i just took it off. I drove it down the road got up to about 35 didnt notice anything.
2. How important is it to remove the plastic spacer that are all ready in the rear? I forgot to remove them and now the ass sits a lil high but im ok with having some rake. The rear flexes wll enough that i will end up using the extra space any ways.
1987 Suzuki samurai BONE STOCK
(SOLD)1990 Samurai 1.6 8v swap, Arb front air locker, spool rear, RRO coil suspension, Chromoly front axles, 33x13.5-15 Swampers, ARB Bumpers, Slider, fender flares, 6.5:1 transfer case, True beadlocks, 1.5" wheel spacers,Roll cage. All in all a lil over 10k in parts uuuggghhhh!!!!!(SOLD)
(SOLD) 2000 Chevy tracker, 4 door, 4x4, auto trans, 2 inch lift,265/70r16 (SOLD)
(TOTALED)1995 tracker lsi, tintop, 3speed auto trans, 2 inch lift, 2 1/2 inch exhaust, 30x 9.5 bfg a/ts, custom front bumper.(TOTALED)
  • 4314
  • 167
Re: Just instaled jeffs 2" lift have a few questions!!!
« Reply #1 on: July 15, 2012, 06:45:06 PM »
The swaybar can be quite controversial - if it's a daily driver or will see any highway use at all, I say refit it - a longer end link might make it easier.
When you were test driving, did you try turning corners?  Try a quick left/right/left or right/left/right manouver (keep the speed down please), for example one that you would have to make if a child darted out into the street in front of you. or if something fell off the back of a pickup truck in front of you.
Offline kreator
  • 634
  • 15
« Reply #2 on: July 16, 2012, 08:35:15 AM »
X2  ! refit the sway bar ! I took mine off and hauled it to go wheeling and got and liked it , but when we got home I drove it to the store and had a young boy on a bike come out in front of me and almost lost it !
Offline jeff1997
  • 1228
  • 27
« Reply #3 on: July 16, 2012, 12:32:05 PM »
I drove for years without my sway bar and had no problems. You cannot drive like a madman but it is safe for normal driving. I also did not take the rubber spacers out in the rear and it was fine, a little high in the rear but no biggie.
3" Masterkit1 body lift
Custom strut spacers
