Lift
  • 26 Replies
  • 4399 Views
Re: Lift
« Reply #15 on: February 23, 2011, 07:07:39 PM »
I believe the GV springs are a bit shorter then the XL7, and a bit stiffer.  But I don't know for certain, I haven't had a set sitting next to one another.  The after-market XL7 springs are softer then the aftermarket GV springs, the same weight as the aftermarket 4 door springs.  Just taller.
Offline mcm4ss
  • gotta love the zuki.
Re: Lift
« Reply #16 on: February 24, 2011, 09:00:35 AM »
I just joined, thought I would share.  found a GREAT cheep way to get a very inexpensive coil spacer, its adjustable and hasnt broken yet.  go buy a 2" shower drain and use it.  I have put the sidekick through its paces just fine, and its never wimpered yet.  FYI.
4.5" total lift
all handmade parts
Love kicking jeep ass
Offline Jluck
  • 1389
  • 40
Re: Lift
« Reply #17 on: February 24, 2011, 09:26:00 AM »
this we have too see.....pic's??????? ??? ???
Offline jeff1997
  • 1228
  • 27
Re: Lift
« Reply #18 on: February 24, 2011, 03:06:56 PM »
Me too. I need to see a picture of that. I may be put out of business by a plumber!!!
3" Masterkit1 body lift
Custom strut spacers
Offline reese
  • 41
Re: Lift
« Reply #19 on: February 24, 2011, 03:46:19 PM »
I just installed Jeffs lift on my 95 4 door last weekend with new struts, Mustang rear shocks and camber bolts. His spacers are top notch, the rear is easy but it takes a while to get the fronts installed, you need to pull the passenger axle, unbolt the drivers axle to get the a arms low enough to get the spring back in, so get a coil spring compressor (most Oreillys and autozones loan these for free! along with other tools). Now my ride looks great, I put some 30x9.5x15 on the stock rims and they rub a little at full lock but I will get under there this weekend to adjust that. All in all this is quite a good deal and down the road you can go for a "real" lift if you think you need one. Erik in Portland
Thanks,
Erik in Portland
95 4 door
Re: Lift
« Reply #20 on: February 24, 2011, 07:18:24 PM »
Yeah, gotta see it.  I assume you are talking about a brass one?
Offline Jluck
  • 1389
  • 40
Re: Lift
« Reply #21 on: February 24, 2011, 11:06:26 PM »
looks like hes offline, maybe at the morgue?  :laugh:
Offline jeff1997
  • 1228
  • 27
Re: Lift
« Reply #22 on: February 25, 2011, 05:42:56 AM »
TOO FUNNY  :laugh: :laugh: :laugh: I truly laughed out loud!!
Re: Lift
« Reply #23 on: February 25, 2011, 10:49:18 AM »
Good to know. This is probably route I'll go with my Sidekick, too. What did you get for struts?
- Andy (also in Portland)
GO PREPARED! www.WARN.com
Like us on Facebook: Facebook.com/WARNfans
Follow us on Twitter: Twitter.com/WarnIndustries
Offline jeff1997
  • 1228
  • 27
Re: Lift
« Reply #24 on: February 25, 2011, 01:32:27 PM »
I include strut spacers.
Offline reese
  • 41
Re: Lift
« Reply #25 on: February 26, 2011, 09:47:50 PM »
Quote from: reese on February 24, 2011, 03:46:19 PM
Andy,
I got a set of Monroe Monro-Matic Plus struts up front, longer Monroe 33137 shocks for the back and camber bolts from Rockauto. It rides so much better now.
Erik in Portland
95 4 door Sidekick
-60k miles!
Jeffs 2" spacer lift
30x9.5 tires
fresh fluids and tune
Thanks,
Erik in Portland
95 4 door
Re: Lift
« Reply #26 on: February 27, 2011, 05:39:27 AM »
:laugh: :laugh: :laugh: :laugh:
