choke problems
choke problems
greg51
13
FISHING IN THE BIGHORNS
choke problems
November 28, 2010, 06:02:08 AM »
I have a 88 Suke that the water choke is not opening all the way at the first mark on the temp gauge. What should I do?
Drone637
8121
116
Evil Cow
Re: choke problems
December 03, 2010, 11:20:20 AM »
Is this a stock carb? Is it an issue with the choke not opening or the temp gauge that operates it not telling it to?
One option is to switch to a manual choke.
greg51
13
Re: choke problems
December 10, 2010, 05:13:18 AM »
Does anyone make a manual choke kit for this? Stock carb. I put some cardboard in front of radiator so it would run warmer and the choke then opens farther. Seams to have helped the gas milage. Not sure yet.
Last Edit: December 10, 2010, 05:16:49 AM by greg51
rascott
669
15
tread lightly monkeywrench a little
Re: choke problems
Reply #3 on:
December 10, 2010, 07:54:36 AM »
does it eventually open all the way?
seems that if you have to block the radiator to warm it up, the thermostat may be faulty or wrong temp.
i think 185 deg. is right?
Drone637
8121
116
Evil Cow
Re: choke problems
Reply #4 on:
December 10, 2010, 01:06:04 PM »
I'm not sure if there is a kit, but adding a manual choke is pretty easy to do. Or you can find an SJ-410 and pull the choke kit off it it. You should be able to fab up a mount to use it on the Hitachi carb.
