Harley CV carb swap.
  • 2053 Views
« on: March 10, 2012, 09:12:55 PM »
I'm having the worst time trying to pass the air quality test with my 87 samurai, it has the aisin carb on it right now, but i'm failing on the NO2. I am considering doing the CV harley carb swap. Can anyone give me a little insight on this, adaptors I would need or year of harley it needs to be from? any insight would be helpful, thanks.
Offline Boxcar
  • 936
Re: Harley CV carb swap.
« Reply #1 on: March 11, 2012, 08:50:39 AM »
petroworks has the best kit. Late 80s 40 to 44 mm Keyhin cv. From a Harley
 But it won't pass smog......
 You'd have better luck with the Toyota 1200cc carb conversion....As it can be made to look fairly stock.
The cv can not.....Boxcar....
PS : Cv might give better top end , But the yota is much easier to install . The yota also out performs the Webber....
God Bless
« Reply #2 on: March 11, 2012, 03:51:49 PM »
Have you checked ignition timing?
