4 door brakes on my 94 2 door sidekick
  • 17 Replies
  • 6937 Views
« on: June 21, 2010, 01:15:11 PM »
I want to put 4 door brakes on my 1994 2 door sidekick, I got the rotors pads and calipers, the rotors are the same diameter but thicker because they have cooling fins and are double thick so they wont fit in the stock caliper stand and the new caliper is a little longer as are the pads. so my question is will 4 door caliper stands bolt to my 2 door spindles, if so is that all I need besides what I have. I want to know because my local parts store doesn't carry the stands so I don't want to not be able to return them if they don't work and be stuck with them. -Thanks Craig
Offline MUD CHILD
  • 355
  • 9
Re: 4 door brakes on my 94 2 door sidekick
« Reply #1 on: June 21, 2010, 02:53:41 PM »
You need the 4 door spindle as well
NO DITCH TO DEEP NO HILL TO STEEP
http://srcustoms.ca/
« Reply #2 on: June 21, 2010, 05:13:42 PM »
Are you sure?  We bolted a set of 4 door front brakes and calipers directly to BRD HNTR's two door without issues.
We didn't bother with the rear brakes as we didn't feel like swapping the backing plates.
Offline biker
  • 730
  • It's a sickness I tell ya
« Reply #3 on: June 21, 2010, 05:56:34 PM »
I've done this several times and the calipers and brackets will bolt right on to your spindle. You may need to trim the tin rock shield slightly to clear but otherwise very easy.
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
« Reply #4 on: June 21, 2010, 08:27:02 PM »
I did a 4 door brake swap, spindles are the same, you just need the 4 door
caliper mounts and I got the vented rotors as well, then just make sure
you get the 4 door pads when you change your brakes.
This is one of the best upgrades I did for bigger tires
« Reply #5 on: June 21, 2010, 08:52:45 PM »
Amen to that!
« Reply #6 on: June 22, 2010, 06:40:51 AM »
cool Ill order the 4 door stands thanks guys!
« Reply #7 on: June 22, 2010, 12:01:09 PM »
I did this swap and used the 4dr drums as well to keep the brakes balanced.
« Reply #8 on: June 22, 2010, 12:58:50 PM »
Funny thing on my 95, when I went to the local parts store to get replacement rear brake parts, shoes and wheel cylinders, nothing for the 2 door matched up. When we looked up the 4 door stuff, everything matched up perfectly. Maybe some kind of mid year, "use up all the leftover parts" deal when they assembled my rig. Doesn't really matter, they still don't work for crap. Still want to do a disc conversion to the rear eventually.
Offline tracker954x4
  • 73
    • Instagram link
« Reply #9 on: June 24, 2010, 12:54:10 PM »
I'm running the front calipers off a 4 door on my 2 door.
Happened to be all i had available during last minute late nioght repairs before going wheeling the next day. ;D They work great though, no problems at all.
tracker954x4
« Reply #10 on: June 27, 2010, 05:38:14 AM »
If you're running the two door rotors then you need to keep an eye on pad wear, the 4dr rotors are thicker and you wouldn't want the pads dropping out.
Offline ncspack7civic
  • 108
« Reply #11 on: July 01, 2010, 06:47:35 AM »
Ok so all i need are the caliper brackets, not the entire caliper and bracket correct?
  • 73
    • Instagram link
« Reply #12 on: July 01, 2010, 07:53:11 AM »
Good point. I hadn't thought of that ::)
tracker954x4
« Reply #13 on: July 01, 2010, 09:50:30 AM »
You need the caliper, thats what gives you the extra braking. The piston on a 4-dr caliper is 20% larger by area than the piston on a 2-dr caliper. The caliper is also wider to allow for the extra thickness of the ventalated disc.
« Reply #14 on: July 02, 2010, 06:40:33 AM »
I have looked at five online parts supply companies and none list 4dr rotors and calipers. All the same from 89-97. Do I have to get salvage parts to do this upgrade or buy parts from the factory?
Wayne inTexas
Edit: I used Suzuki instead of Geo and the 4drs started showing up. No 4drs for Geo?
« Last Edit: July 02, 2010, 06:50:27 AM by Falcongunner »
94 Geo Tin Top, 8V, 5sp, 2" body lift
