« Reply #1 on: July 24, 2012, 08:00:37 AM »
Dual transfer cases gives you the ability to compound your low rang gears (Low range + low range = lower range). Installing different gearing in one of the gear cases will give you three different low range abilities. Installing dual cases in Suzuki's is not easily done and hard to get expensive kits are not readily available. Different models of Suzuki's require different solutions.
93 Tracker,XL7 springs & 1" raised spring pads in front with YJ springs in back, home built bumpers rear & front (w/winch), 2" x 4" rock tubes, ARB front & rear, converted Sami rear to IFS, 33x12.5x15 aluminum rims, roll cage, 2.7L w/5 speed auto.
