2.0L VW
  • 10 Replies
  • 2839 Views
Offline jow003
  • 403
2.0L VW
« on: October 12, 2010, 05:40:09 AM »
So my cuz has a built out 2.0 that he says hes put about 2500 into but doesnt need/want it anymore and would sell it to me for 1000.  My biggest questions are:
1.  Will it work
2.  Will it fit
3.  does anyone make somthing that i can use to bolt the engine to the transmission
4.  If im going to do the 2.5" exhaust, would this be the time to doit
Has anyone ever seen a conversion like this?
« Last Edit: October 12, 2010, 05:45:43 AM by jow003 »
BUY MY STUFF!! pm for details
87 Samurai...
5" SPOA/OTT -RRO
1.5" leaf springs-OME
RUF conversion-Trail Tough
1" shackles
33x1250x15 MTZs
15x8- DC-2s
Re: 2.0L VW
« Reply #1 on: October 12, 2010, 08:41:18 AM »
Yes, do it, you will need the injection system and the computer
to run it, so keep that in mind if your cuz is keeping the car and
not the engine.
You driving a Samurai or Track/Kick?
adapter plates available for the Track/Kick trans, not sure about the Samurai
Offline jow003
  • 403
Re: 2.0L VW
« Reply #2 on: October 12, 2010, 08:50:29 AM »
Samurai, found a company that makes an adapter for about 500.  its an engine that he built to put in his car but decided to go a different route and basically sitting on a palat.
also tryin to figure out the cheapest way to get there (riverside, ca from colorado).  best i can figure goin to get this and the bumpers done while im there would cost me about 2100 before i rent a trailer and food, and random parts needed
87 Samurai...
5" SPOA/OTT -RRO
1" shackles
33x1250x15 MTZs
15x8- DC-2s
Re: 2.0L VW
« Reply #3 on: October 12, 2010, 08:55:22 AM »
 :o $2100, what are you driving a motorhome
Cost me less than $500 to drive from here (I'm close to riverside) to Moab
in my F350 and camper pulling my Sidekick, and what do you need a trailer
for? or are you in a car?
Offline jow003
  • 403
Re: 2.0L VW
« Reply #4 on: October 12, 2010, 09:45:05 AM »
hes sellin me the engine for 1k gas will be i estimate to be about 500 (driving a 5.3L Chevy Z71) and bc the bumper i used to tow my samurai fell off(damn you whoever welded it on) i cant flat tow it so id need to get a uhaul trailer or something
87 Samurai...
5" SPOA/OTT -RRO
1" shackles
33x1250x15 MTZs
15x8- DC-2s
Offline KJMac
  • 280
Re: 2.0L VW
« Reply #5 on: October 20, 2010, 10:22:21 AM »
Are you going to get the VW 2.0L? I would like some feedback< I'm considering the same conversion.
I found a nice engine, I just dont have the money for the conversion. Any idea on cost for the conversion
parts?
thanks
KJ
1994 Kick, 16v,header.2.5" exhaust,ported MAF,home made mufflers, K&N filter,5" lift with jeep LJ front springs on the rear and Ford ranger springs on front with 2 3/4 spacers,OME struts with 3" strut spacers,31/10.5 Hankook Dynapro MT on 15x7 black D's.
Offline jow003
  • 403
Re: 2.0L VW
« Reply #6 on: October 21, 2010, 05:16:10 AM »
my cousin just picked up the gas engine yesterday, ended up walkin away with it for 550 with clutch/flywheel, the entire harness , ECU etc.  the conversion kit(plate that allows you to connect the sami tranny to vw engine) is 425 here: http://www.acmeadapters.com/store_engine.php
As for everything else im not sure yet.  My cousin is gonna tear down the engine to see what needs to be replaced, at the least it'll be seals and such just to prevent probs in the future.  Ill try and keep a tally in my build thread of $$ spent
http://www.zukiworld.com/forum/build-diaries-how-to-diy/87-sami-project/
where are you located KJMac?
87 Samurai...
5" SPOA/OTT -RRO
1" shackles
33x1250x15 MTZs
15x8- DC-2s
Offline KJMac
  • 280
Re: 2.0L VW
« Reply #7 on: November 03, 2010, 10:05:50 PM »
I'm in Monmouth, OR. Just west of Salem about 12 miles. looking forward to your transplant!
Offline jow003
  • 403
Re: 2.0L VW
« Reply #8 on: November 04, 2010, 06:03:17 AM »
thanks, im gonna try and take as many pics as i can to document and hopefully help someone else that might wanna do this
I know this is a dumb question but o well, I assume my top speed will increase but with 6.5 t-case i know it drops, so what do you think i can expect (fyi the power will be ~135hp ~140ft tq)
« Last Edit: November 04, 2010, 06:22:27 AM by jow003 »
87 Samurai...
5" SPOA/OTT -RRO
1" shackles
33x1250x15 MTZs
15x8- DC-2s
Re: 2.0L VW
« Reply #9 on: November 05, 2010, 01:56:28 PM »
Your main problem isn't going to be power but gearing.  If you want to see what your projected top speed is you can build your SJ on a transmission calculator.  I use the one at http://www.solemnwarning.net/transmission/ but there are a couple more out there that work just as well.
Just put in your redline, select the transmission and transfer case combo and go.  Since it was made by a brit you will need to select the SJ series.  SJ-413 for your Samurai 5 speed.
Offline jow003
  • 403
Re: 2.0L VW
« Reply #10 on: November 05, 2010, 02:15:30 PM »
so supposedly my top speed right now is about 50.  after the swap it'll be about 65
87 Samurai...
5" SPOA/OTT -RRO
1" shackles
33x1250x15 MTZs
15x8- DC-2s
