sami articulation (flexing)
  • 2090 Views
Offline ColtonP
  • 147
« on: October 25, 2010, 04:54:51 AM »
I have a 88 sami that has a 6-8 inch shackle lift. Stock springs. I was wondering what would b the best way to get more flex out of it??? Disco??? Remove rear shocks ??? Any tips and suggestions would be great THANK YOU
1987 Suzuki samurai BONE STOCK
(SOLD)1990 Samurai 1.6 8v swap, Arb front air locker, spool rear, RRO coil suspension, Chromoly front axles, 33x13.5-15 Swampers, ARB Bumpers, Slider, fender flares, 6.5:1 transfer case, True beadlocks, 1.5" wheel spacers,Roll cage. All in all a lil over 10k in parts uuuggghhhh!!!!!(SOLD)
(SOLD) 2000 Chevy tracker, 4 door, 4x4, auto trans, 2 inch lift,265/70r16 (SOLD)
(TOTALED)1995 tracker lsi, tintop, 3speed auto trans, 2 inch lift, 2 1/2 inch exhaust, 30x 9.5 bfg a/ts, custom front bumper.(TOTALED)
Re: sami articulation (flexing)
« Reply #1 on: October 25, 2010, 11:56:25 AM »
One of the best ways to get some travel would be to get rid of the shackle lift and switch to a SPOA (Spring Over Axle) lift and some longer shocks.  YJ springs with folding shackles would be your best bet staying with springs, or you can switch to a full coil over suspension.
You don't want to run without shocks.  It makes your vehicle a road hazard and is unsafe at any speed.
Offline ColtonP
  • 147
« Reply #2 on: October 25, 2010, 12:58:51 PM »
It never goes on the road more then 4 miles at a time and always below 30mph. other then that its hauled to trails
« Reply #3 on: October 28, 2010, 01:19:08 PM »
To each their own.  I still like running shocks, just measure out your flex with the shocks pulled off then figure out how to mount them without restricting anything.  Best of both worlds.  :)
Offline Hubbachubba
  • 19
« Reply #4 on: October 28, 2010, 06:18:43 PM »
I agree, yj springs are the way to go, i have them on my samurai with the SKY BRACKETS, they are a simple install, but you will need longer driveshafts, brake lines, shocks and do some modifying to your shock mounts, i cut the inner fenders to get the most travel out of my front suspension. I did all the fabrication to mine myself so i saved a little. good luck
Offline my996duc1
  • 222
« Reply #5 on: October 29, 2010, 05:38:08 AM »
If you are stuck with your spring setup that you have now, I would atleast get longer shocks. This way you can keep the shocks as they will help off road as well.
I really like the Trail Tough YJ missing link setup. Rides smooth and flexes decent too.
The install isn't too hard. I did mine in the garage of my apartment.
Here are the online instructions of the TT kit :
http://www.zukiworld.com/month_050104/feature_trailtough_yjlift_install.htm
« Last Edit: October 29, 2010, 05:41:11 AM by my996duc1 »
1987 Tintop / 1.6 16V ps & ac / 6.4 t-case Twisted TT / 4.30 R&P Hybrid rear / Double Tough axles / Shrockworks all around / ARB f&r / Mighty Kong & TT full skid / DS disconnect / CV shafts f & r / YJ missing links f & r / Petroworks tintop cage / 15 gal Tank / 31" x 12.50 Pro Comps
