I was browsing through the gallery and saw your rack. It looks great! Could you elaborate on it?
QUESTIONS:
What is the rack from?
Rack Siize?
How much weight do think it can hold, MAX?
Does the rack have to come off to remove your softtop?
If you have to remove it, do you remove it with the brackets attached to the rack, or do you remove the rack from the brackets?
Can you explain how you attached it to the sides, close up pics would great!
If you were to build it again, what would you do different?
Thanks!
Ryan
