Im new to the 16v some mod questions
  • 24 Replies
  • 5262 Views
Re: Im new to the 16v some mod questions
« Reply #15 on: October 01, 2009, 02:48:34 PM »
we do a grind for the 16v, its a torque grind not a top end grind. ALSO, Im working on pistons. I have to buy a ton of them to get an order. I'll keep you all posted.
I need to get my 16V into my SJ now or this is going to cost me money  :)
Seriously, I'm working on remapping the ECUs for the late model 16Vs, once I've done a map for a standard (ish) motor it has to be build time  :) :)
« Last Edit: October 01, 2009, 02:50:35 PM by Rhinoman »
Offline Minmatar
  • 262
  • That lake is just too clean....right zuki? >=)
« Reply #16 on: October 01, 2009, 03:37:38 PM »
Never rebuilt a motor Furthest i've gone motor wise is a head swap.....after rebuild. Lower end cant be that hard.....My end product i want:
Rebuilt G16KV Head (torquer cam)
Rebuilt lower end
D/T Header
Custom 2" Back
Figure out my cold air intake with Throttle spacer
Drop clutch fan (replace with Electric fan / Push pull theory)
(still looking for alternator swaps)
Id love 2 cores. But money is so damn tight. Pisses me off. (not even lifted yet >=O)
<)O.o(> NO!!!!! *as the sidekick rolls* My beer =(
« Reply #17 on: October 02, 2009, 04:39:52 PM »
Rebuilt lower end
D/T Header
Custom 2" Back
Why do you want a throttle spacer on an MPI engine?
Offline mrfuelish
  • 2862
« Reply #18 on: October 03, 2009, 11:54:01 AM »
maybe it would help with bottom end or he is looking at the ones that has the swirls in it for spinning the air as it goes in but would only work at Wot. ?
Offline Mac500r
  • 69
  • Alot more to do!
« Reply #19 on: October 07, 2009, 10:14:54 PM »
Port the Mass Air Sensor! I noticed a good increase by de-screaning and porting the MAS. When you pull the screen assembly out there will be a step in the plastic housing. I blended that step out and ported thru the housing. Epoxy in the cavities on the outside of the MAS housing fixed it up nicely!
I ported the entire I.D from front to back and trimmed the air director around the sensor probe. The throttle response and power increase was well worth the trouble.
I also cut the ribs out of the air box lid and smoothed the sharp edges around the port that feeds air to the engine. More air volume above the filter feeds more air to the ported MAS! The 2 1/2 inch exhaust and header helped also.
Thanks,
Brent
1996 Tracker 2door soft top.2.5" exhaust,High flow Cat,Home Built Muffler,2" Ironman springs and rear shocks,OME Struts/Mounts Flipped,K&N Filter Modded Air Box,Ported MAS Sensor, spring spacers,A-arm drop brackets,strut spacers.5.5" total susp.lift.33x10.5-15 BFG MT.Home built Bumper,2.5" B/L.
Offline Minmatar
  • 262
« Reply #20 on: October 08, 2009, 09:56:26 AM »
Great Feed Back Guys.
Gotta love the zuki love.
Id love pics of your work on the MAS/Box Mod. To give a clear picture!
Offline Mac500r
  • 69
  • Alot more to do!
« Reply #21 on: October 21, 2009, 02:38:29 AM »
I gave the stuff to my brother because I am going with a different engine in mine. I will try to get some pics though.
Offline KJMac
  • 280
« Reply #22 on: October 30, 2009, 09:27:01 AM »
Mac500r put the box and maf on my kick,it was quite noticeable! I will get pics this weekend. I plan to draw thru the box when I put the turbo on it!
1994 Kick, 16v,header.2.5" exhaust,ported MAF,home made mufflers, K&N filter,5" lift with jeep LJ front springs on the rear and Ford ranger springs on front with 2 3/4 spacers,OME struts with 3" strut spacers,31/10.5 Hankook Dynapro MT on 15x7 black D's.
Offline Minmatar
  • 262
« Reply #23 on: October 30, 2009, 09:34:13 AM »
Fun stuff. I just got paid today and im going hunting in the yards! Need a new wind shield as well as a rear window. Unless someone knows how to fix the back defroster.....it has broken connections on the glass.
Offline Lindenmooch
  • 560
« Reply #24 on: November 02, 2009, 08:54:51 PM »
My back window isn't made of glass.     :P   Can't help you with a rear defrost....but I would like to hear some more about motor swaps/head swaps and power gains.   Mine's old and tired as well....and could use a rebuild.
