trans. coolers
  • 1299 Views
Offline vw505
  • 133
trans. coolers
« on: June 26, 2011, 05:48:51 PM »
Were do you all have your after market trans. coolers mounted. Im thinking of this one.
Re: trans. coolers
« Reply #1 on: June 26, 2011, 08:21:56 PM »
I used a more traditional flat one, put it in front of the intercooler
Offline vw505
  • 133
Re: trans. coolers
« Reply #2 on: June 26, 2011, 10:04:52 PM »
Does any one have a photo of how they have there cooler.
Offline tictac
  • 38
  • What's THAT noise now?
Re: trans. coolers
« Reply #3 on: June 27, 2011, 06:48:12 PM »
ive seen similar set ups on drag cars, but they used it for oil.  needs airflow on it.  good heat sink, but will still need some air flowing.  on the drag car it was on frame.  not so sure good idea to mount like that on a 4x4.  might rip off.  ;D
94 Sidekick. Calmini 3" lift with EDSES. 2.0 engine swap (real soon) 😎
Re: trans. coolers
« Reply #4 on: June 28, 2011, 11:27:44 AM »
Check out replacement radiators.  A lot of them have built in oil coolers.
Re: trans. coolers
« Reply #5 on: June 28, 2011, 10:06:02 PM »
I had my 6 x 10 mounted behind the radiator, because I use an electric fan, and didn't want to loose motor cooling capacity.  I had to go to a bigger radiator, so I got one with cooling coils.
