1.6L 8V questions
  • 1638 Views
Offline airmanwilliams
  • 913
1.6L 8V questions
« on: June 26, 2011, 11:09:02 AM »
ok guys I just picked up a 1.6L 8V motor from a guy to rebuild and put in my samurai.
Should I keep the harley myside kit on my 1.3 and swap it over or run the fuel injection?
I am keeping my headers so I will bead blast the stock 1.6 exhaust manifold and selling it but what price should I ask?
what can a 1.6L 8V valve cover go for if I glass bead it too?
« Last Edit: June 27, 2011, 06:44:26 AM by airmanwilliams »
1993 4door Suzuki Sidekick JX
Re: 1.6L 8V questions
« Reply #1 on: June 26, 2011, 08:23:52 PM »
Do you have the EFI computer? if not, just run the side draft system
  • 913
« Reply #2 on: June 26, 2011, 08:25:30 PM »
yup I have the computer, intake, throttle body, wire harness, distributor, air intake stuff, and instrument cluster. If the opinion is that the sidedraft is best then I will probably try and see if I can get $250 for all of this.
« Reply #3 on: June 26, 2011, 08:35:30 PM »
Over all, EFI is going to be more efficient, and the engine will not stall
or flood on any hills, or upside down for that matter. But you might
get more HP with the side draft carb, not sure how much those flow, and
you might also find a Sammy guy that would like to swap out a stock carb
for a different type
« Reply #4 on: June 28, 2011, 07:41:36 PM »
the best performance is going to be the tbi efi. based on the year, i can modify the harness for you depending on your needs.
email me if you have further interest. robsandfreak|removethispart|@yahoo.com
  • 913
« Reply #5 on: June 28, 2011, 08:06:27 PM »
thanks guys I think im going to hold off on this swap now with the wife wanting another kid money needs to go to other things. I am book marking this though so I dont ask again. Im hoping maybe I can get $500 locally for this motor, harness, computer, instrument cluster, and intake with efi.
