quick tranny question?
  • 1279 Views
Offline Tracker-Kid
  • 50
« on: January 25, 2010, 09:03:25 AM »
ok so i have a 94 tracker with the auto 3 speed and i have a 5 speed tranny out of a 94 tracker but it came off the 16v.
So i want to know if i can put the 5 speed on the 8v??? Dose it just bolt up or what do i need?
IF ITS BROKEN.....  WELD IT!!
Re: quick tranny question?
« Reply #1 on: January 25, 2010, 09:41:53 AM »
Yes, the 5 speed from a 16V will bolt onto an 8V.  You will have to replace the auto flexplate with a flywheel and clutch, of course.
The 5 speed probably has braces that run from the engine to the bellhousing (one on each side of the engine).  You may or may not be able to use these on the 8V (depending on if the 8V has places to bolt them on).  If it doesn't, then just leave them off.
« Reply #2 on: January 25, 2010, 09:44:49 PM »
Braces go to the block, both blocks are the same so they will work
